Espace 3 Problème énorme avec air conditionné
Re: Espace 3 Problème énorme avec air conditionné
Sorry, my wording was misleading. It IS the right computer, but your google search was wrong in calling it "ABS".
And again, your computer is OK. The cause is some other equipment connected to it, which prevents a good reinitialization
If you can't find another similar car nearby to reinit your computer then you might either buy a USED one, which was correcty woring before being dismounted(as suggested by Falcon60) , or try to find which is the failing equipment
It might be a dirty connector, or a temperature captor, or a stuck flap motor. You wil have to check all of them, as this stupid computer does not tell what is wrong!
I sent you by MP a cabling diagram which should be similar (if not identical) to the cabling of your model. Good luck!
Espace III Ph2 2002 2.0 16V expression : 150 000 km
Whether there is electric scheme instrument panel. Please send to me. Espace III 16v 2001.
Qu'il y ait tableau de bord de système électrique. S'il vous plaît envoyez-moi.
https://postimg.org/image/gpk40d0h1/
Hello
What is the number NT 8xxx which is writing in the fuse box behind the passager's foot ?
Probably 8161 or 8166 !
Whit this number, I can send you the good scheme
NT 8166A
I hope you understand me. I need a scheme for the control panel with display.
J'espère que tu me comprends. Je besoin d'un système pour le panneau de commande avec affichage.
https://postimg.org/image/ukieituw5/
pub2n, I wait
See your mp, because the mail have got a problem (to big )
- Modèle : [En cours d'achat]
1fichier.com pour ma part, merci pour ce lien complémentaireFossoyeur a écrit : http://dl.free.fr
Salut Yann,pub2n a écrit :1fichier.com pour ma part, merci pour ce lien complémentaireFossoyeur a écrit : http://dl.free.fr
Je me sers aussi de Dell, pour l'envoi de gros fichiers (entre autres, la *** du "3" !)
- falcon60
- finition : RXT
A participer a un autre sujet de clim pourtant
(Donneur d'organes )
falcon60
I cant solved the problem yet. I'm waiting for my return from vacation electrician. Then dismantle and see. I will inform you what I did.
Je n'ai pas résolu encore le problème. Je suis en attente pour mon retour de vacances de l' électricien. Puis démonter et voir. Je vous informerai ce que je faisais.
ECU Regulee j66 for climate changed and the problem is solved.
ECU Regulee J66 pour le climat a changé et le problème est résolu.
- falcon60
- finition : RXT
I am happy for you
