il faut trouver l'origine de ce morceau de fonte
string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688" string(5) "15688"
dom89 a écrit :je serais toi ,je déposerai la pompe à huile et le carter plastique pour verifier les pieds de bielles![]()
Tu sera fixé en ouvrant le haut... ( laisse le bas ouvert durant ce temps... )KevSpace08 a écrit : Je ne vois pas d'où viendrai ce morceau..mais j'ai ma petite idéeça ne serait pas un bout du palier ACC ?
KevSpace08 a écrit :Voici les photos, des pieds de bielles
Piston ,Bielle N°4 Pistons et bielles N°3 et 2
Piston N°1 ,volant moteur
Endroit ou l'huile s'est quasi vidé de la pompe à huile
Donc voila, j'ai bien verifier, regarde le bas moteur ,si une bielle n'aurait pas frappé dessus (RAS), les pistons partent et reviennent sans soucis...
